cancel
Job type :
Zip Code :
community forums
comments
Garage Ceiling Storage Installation Tips
To install garage ceiling storage there are a important points to keep in mind.
Step 1 – Check the Clearance
Before deciding on a storage product, check to see how much usable space you do have between the ceiling and the top of your other storage or the top of your vehicles. Never have ceiling storage hang lower than 7 feet from the ground to provide enough clearance for any people who might be in your garage.
Step 2 – Decide on a Storage Solution
There are several different types of ceiling storage systems for garages. Consider the items you plan to store on those racks and make your selection accordingly. If you are storing heavy documents or equipment, be sure to buy sturdy steel shelving.
Step 3 – Install Units
Clean the ceiling and wall area and move everything out from underneath the space where you will be working.
Locate the cross beams in the ceiling and be sure to fasten your storage units to those beams. Fastening them to the drywall is a recipe for disaster.
Measure carefully before you install to ensure good clearance from the wall and the right spacing.
Step 4 – Load the Shelving
Think about what you will store in garage ceiling storage. You don’t want to include frequently used items or items that are extremely heavy. Camping equipment is likely a good choice, as are some infrequently needed automotive tools or seasonal recreational equipment.
member comments
Did-it-myself Projects
updated by Rocky1008
did this on 11/07/2009
Garage Shop Organizing
updated by CR8ZR
did this on 1/28/2009
Garage To Bar
updated by jmat1980
did this on 5/11/2008
Garage Remodel
How to Build a Shoe Storage Bench
sponsored articles of the day
