Login Error
Close
Programming A Garage Door Remote
by DoItYourself Staff
Conveniently, a garage door remote allows you to open or close the door without having to get out of your car. You may need to know how to program your garage door remote if you change it or if it's ever lost or stolen.
Step 1 - How Does the Garage Door Remote Work
In an older garage door remote you will find small code switches that turn on or off. The same set of code switches is present in the garage door opener controlling the operation of the door. Newer remotes use a rolling code technology. This type of garage door remote functions by changing the code each time the remote is pressed. A radio frequency allows the remote to send a signal to the garage door opener to go up or down.
Step 2 - Garage Door Remote Frequencies
Radio frequencies are measured in megahertz (MHz). The most common garage door remote frequencies are 300 MHz, 310 MHz, 315 MHz, 318 MHz or 390 MHz. The frequency for a garage door remote or motor is usually printed on them.
Step 3 - Choosing a Garage Door Remote
Match your garage door remote to your garage door opener by using the same manufacturer. The following are some of the companies that sell garage door remotes.
  • Liftmaster
  • Genie
  • Allstar
  • Linear
  • Stanley
Step 4 - Programming Your Garage Door Remote
Programming your garage door remote and clearing the current garage door remotes from the opener varies slightly according to the model of your garage door system.
All garage door openers have a learn button. To find the learn button you may have to remove the light cover on the garage door opener. The learn button can be black or a color.
To program a new garage door remote into the system hold the learn button until the indicator light blinks on the opener. While the indicator light is blinking press the button on your remote. Test the new garage door remote by pressing once to see if the door moves.
In most cases, erasing remotes from the garage door system is accomplished by pressing the learn button until the indicator light stops blinking. When the blinking stops press your remote button down and release.
A garage door opener can only maintain five remotes or four remotes and one keyless entry.
Step 5 - Programming Garage Door Remotes That Have Code Switches
Code switches in your garage door remote and opener have to match. That means the code switches are placed in the same position.
Sometimes the garage door opener doesn't have code switches. Instead the opener will have only a learn button. To program the garage door remote push the learn button and at the same time press the garage door remote.
To find more information about programming garage door remote go to www.doorsandopeners.com or www.usdoorcontrol.com.
 forum activity
