Login Error
Close
Garage Door Sensor Alignment
by DoItYourself Staff
A garage door sensor is an important safety feature that needs to work correctly. If you are having problems with your sensors they may be out of alignment.
Step 1 - Before you Start the Alignment Process
Always turn off the power when working on the sensors.
Step 2 - Moving the Garage Door Sensor
The sensors should measure approximately 4 to 6 inches from the garage floor. Give yourself the ability to move the garage door sensor for adjustment by loosening the screws on the sensors.
Step 3 - Leveling the Garage Door Sensor
Attach a string to each garage door sensor and adjust them to the same height using a level. The sensor height should not exceed six inches.
Step 4 - Completing the Alignment
To finish the process tighten the sensor screws then check the alignment again using the string and level.
Step 5 - Checking the Alignment
Turn on the power. To test the garage door sensor roll a ball through the sensors while operating the garage door.
 forum activity
