cancel
Job type :
Zip Code :
community forums
comments
Worry-Free Garage Floor Paint
By using the right brand of garage floor paint, you can transform your garage floor into a durable yet attractive centerpiece of your garage. Garages can become more than just a place to keep your car and store some loose items. Today, the garage is so much more, some include a workshop, gym or just about any other use you could possibly think of.
What is Garage Floor Paint?
There are several different types of garage floor paints available on the market today with each having varying degrees of durability and style. The most common type of garage floor paint used by homeowners and contractors alike are epoxy based. These paints are a mixture of paint and epoxy chips that are applied in several steps. The resulting product is highly resistant to most stains and impact damage. In fact, manufacturers are so confident in their abilities to prevent damage that they offer lifetime warranties for most of their products.
The basic components of an epoxy garage floor paint system consist of a base coat, top coat, and epoxy chips. Some manufacturers will include a concrete cleaning solution in these system kits to prep the slab before applying the paint. Companies offer a huge selection of colors for both the base coat of paint and the epoxy chips that are applied in the paint. The resulting contrasts of colors are what makes them an attractive design feature for most garages.
Applying Epoxy Paint
Applying an epoxy garage floor paint is easy enough for even the novice installer to complete.
As with any garage floor installation, thoroughly vacuum the concrete slab before applying the base coat.
Starting with a small section, roll out the base coat using a standard paint roller fitted with a heavy knap for rough surfaces such as ¾".
While the paint is still wet sprinkle on the epoxy chips.
Repeat these steps until the entire floor has been painted and covered with epoxy chips.
Once the base coat has dried according to the manufacturer's specifications the top coat is then applied over the entire garage floor. The top coat seals the base coat and epoxy chips while also giving it a high gloss shine.
Installing the right garage floor paint will ensure that you get years of use out of your floor. It will also protect your floor while making it easy to keep clean. As most homeowner will attest, it takes a lot less effort to clean an epoxy coated garage floor than a uncoated concrete garage floor. With all the chores and "to-do" lists for around the house, the last thing you want to do is add cleaning the garage floor to that ever growing list.
member comments
Did-it-myself Projects
updated by Rocky1008
did this on 11/07/2009
Garage Shop Organizing
updated by CR8ZR
did this on 1/28/2009
Garage To Bar
updated by jmat1980
did this on 5/11/2008
Garage Remodel
How to Build a Shoe Storage Bench
sponsored articles of the day
