Login Error
Close
Garage Floor Repair Made Easy
by DoItYourself Staff
Homeowners don't have to worry about excessive costs of garage floor repair because there are several products available that make a snap. Even the best finished floors are subjected to wear and tear and will have to fixed up at some point.
Clean First
Before tackling any garage floor repair, it's essential that the floor be swept clean and then vacuumed of any loose debris. It's especially important to clean the damaged area to be repaired. Loose debris and dust will prevent the repair material from properly bonding to the concrete floor.
Pick the Right Filler
Next, depending on the type of damage, the proper material should be selected and applied. An epoxy based filler would be the product of choice to repair noticeable cracks in the concrete floor. These products are usually applied with a caulking gun and are ideal for cracks since they can expand and contract to compensate for the expansion and contraction of the concrete.
For depressions and pit marks, a concrete filler product is the best choice for this particular type of garage floor repair. Simply follow the mixing instructions from the manufacturer and apply the material with a floor trowel over the affected area. Make sure you follow the recommendations of the manufacturer regarding the drying time of the product.
With the products available today, garage floor repair has become a relatively quick and painless procedure.
 forum activity
