cancel
Job type :
Zip Code :
community forums
comments
Get Rid of that Garage Floor Stain
You don't need expensive equipment or solutions to remove a tough garage floor stain. A good citrus based cleaner, a bristle brush, and a little elbow grease can help you eliminate even tough stains.
In the past, when tackling a stubborn garage floor stain, the only options available were volatile chemicals that required you to scrub until your arm fell off. Now there are citrus base cleaners that are not only safer to use, but are much more effective against any stain imaginable.
To remove a garage floor stain, just follow the manufacturer's instructions on applying the solution. The citrus extracts are a great natural chemicals to cut through the toughest grease and oil. Once the solution has been applied you just need to scrub the stain with a bristle brush to effectively remove it.
Nobody wants their beautiful garage ruined with an ugly garage floor stain. But you can rest easy knowing there are citrus based cleaners that can tackle the toughest stains imaginable.
member comments
Did-it-myself Projects
updated by Rocky1008
did this on 11/07/2009
Garage Shop Organizing
updated by CR8ZR
did this on 1/28/2009
Garage To Bar
updated by jmat1980
did this on 5/11/2008
Garage Remodel
How to Build a Shoe Storage Bench
sponsored articles of the day
