Garage Wall Covering Options for the Budget Conscious
Garage wall covering is something that people tend to struggle with. There are a wide variety of options and choices. Many people find themselves overwhelmed by all of the choices. Even people that are on a tight budget or want to spend the least amount possible for their garage walls have a wide range of options for covering the walls in their basement.
Paint Coverings
Paint is one option that many people consider when deciding on garage wall covering. There are some paints that are inexpensive. However, it is important to keep in mind that in most instances exterior paint is better to use in a garage. It is more durable and easier to maintain than interior paint.
Wallpaper Coverings
Wallpaper is fairly inexpensive in most cases. You could decide to do your garage wall covering with wallpaper. The thing with wallpaper is that it is not as durable as some other coverings. If there is a lot of moisture or a lot of dirt in the garage, it is going to be hard to keep the wallpaper clean and to keep it from peeling.
Pegboard or Corkboard Coverings
Another option is to do your garage wall covering in pegboard or corkboard. This is an inexpensive way to cover your walls. It is also very functional. You can add hooks or pegs to the wall and increase your space and usable area of the garage.
Other Options
These are just a few of the options that you can use when thinking about garage wall covering. They are all budget friendly and easy to do. It is all a matter of style and personal preference.
