Login Error
Close
Garage Wall Panels vs Drywall
by DoItYourself Staff
Being aware of the qualities of garage wall panels will be necessary when going through the process of constructing a garage. Comparing them with drywall will help you to determine which material is best for the project.
Soundproofing
If your garage requires a certain level of soundproofing because of the work that is undertaken within it, you may find that garage wall panels will be the better option. They are more likely to be designed to prevent sound escaping.
Installation
The manner in which garage wall panels are installed will need to be considered to determine how much work is necessary. Drywall can be used at any point in a property, while garage panels are specifically designed for the garage.
Use
Garage wall panels are available in a number of different forms, which will enable you to make use of the one most beneficial to you. While drywall will simply form part of the construction, some garage panels can offer other options, such as additional storage.
Insulation
Garage wall panels can be specifically created to offer some heat insulating qualities, which can help when you want to regulate the conditions in the room. Fitting drywall can provide an effective barrier but will not insulate in the same way.
 forum activity
