Garage Woodworking Shop: Best Lighting Explained
A woodworking shop provides a homeowner with a place to work on creative wood projects. An effective woodworking space requires the proper lighting options for both visibility and safety. Consider the types of lighting available before you make your decision on fixtures and locations.
Direct Overhead Lighting
This source of light provides a realistic environment. Using this type of light, woodworkers can comfortably see well enough to complete their projects. Installing additional reflectors to the overhead light fixtures will prevent shadows that can cause visibility problems. Reflectors should be used with both incandescent and fluorescent lights.
Task Lighting
Task lighting is also very important in a woodworking shop. They can be placed anywhere fine detail work is being done. High powered spotlights make it much easier to see small pieces. Task lighting that can be moved around to different locations in the workshop, is the best type to use.
Types of Light
Incandescent fixtures provide a bright source of light that rarely dims over time. Fluorescent fixtures are energy efficient and provide a light source free from shadows. The bulbs last longer and require changing less often. They do dim over time, reducing light quality. Be sure to consider the benefits of both types of light when choosing your workshop fixtures.
