Login Error
Close
Gas Fireplace Mantel Decor: What You Should Know
by DoItYourself Staff
When choosing a gas fireplace mantel, you will find that there are numerous available options. However, be sure to consider the below guidelines before you make your purchase of a mantel.
What You Should Keep in Mind
When choosing a mantel, keep in mind the model number and measurements of your gas fireplace. The sizes and shapes of each fireplace vary, so you could end up with mantel that doesn't properly fit. You also want to think about the size of the room that contains the fireplace. Too large of a mantel could overpower a small room. Additionally, consider having your mantel custom built for you. You can take advantage of the multitude of materials that are available as well as add your own personal touch to the mantel.
What You Should Avoid
Make sure to avoid purchasing a mantel if you have not first fire-proofed the area where the mantel will sit. Use the appropriate insulation and materials, such as fire-reinforced drywall, behind the mantel in case of a fire. Also, avoid blocking any of the air intake or blower exits of the fireplace. Although a large, decorative mantel may look great, it can cause fire hazards if it blocks the airways of the fireplace.
 forum activity
