Login Error
Close
Gas Fireplace Repair: Troubleshooting Basic Problems
by DoItYourself Staff
Gas fireplace repair can be daunting, depending on the problem that arises. However, there are some basic issues that you can repair on your own without too much trouble. The following tasks can be performed by you to check your fireplace and repair some basic problems.
Check the Pilot Light
Should your fireplace not turn on, it could be that the pilot light has been blown out. In order to find out, simply open the vent and you will be able to determine whether or not the small flame is out. If it is, simply re-light the pilot with a match or a lighter and test to see if the fireplace turns back on.
Check Voltage and Gas Valve
If you are finding that the main burner is being a bit sluggish or is simply not coming on at all, then you may have some dirty or loose wiring. You may also want to check the generator to find out how much energy it is providing for the fireplace. This way, you can check to see if the voltage is not adequate for the main burner and adjust as necessary.
Check the Thermocouple
This could simply be because your thermocouple is not screwed in tight enough within the valve of the fireplace. Take a look at the gas control valve and check to make sure that the thermocouple is sturdy. While you are there, ensure that all of the wiring and tubing are correctly placed and functional.
Looking for a new fireplace, fireplace fender, accessories or more? Compare types, brands and prices with our Fireplaces Buyer's Guide.
 forum activity
