Login Error
Close
Gas Tank Repair: How to Repair a Hole in the Gas Tank
by DoItYourself Staff
what you'll need
  • Lacquer thinner or acetone
  • Container for the gas and residue
  • Drywall screws
  • Duct tape or masking tape
  • Putty
  • Plastic container (for mixing the sealer)
  • Plastic wrap
  • Epoxy Sealer
  • Knife
  • Rubber band
A gas tank repair can be done at home instead of taking your car to the workshop and having a professional working on it. Minor leaks on your car’s gas tank can be solved immediately. If you suspect that your car’s gas tank is leaking, you might want to perform necessary check ups to trace the main culprit and have this problem fixed.
The epoxy repair method is easy to follow and works very well in fixing tiny, unnoticeable holes in your gas tank. It can save you lots of money and time and can prevent unwanted consequences. You don’t have to go to and consult a professional to resolve minor gas tank problems and leaks since you can perform this simple task by follow these steps.
Step 1 - Initial Inspection
First, do a thorough inspection on your gas tank. Feel it with your hands and visually inspect it for tiny holes and minor leakage.
Step 2 - Remove your Gas Tank
Once you have confirmed your suspicions, carefully unscrew the tank and remove it from your vehicle. Completely remove its contents into another container.
Step 3 - Drain any Residue
Add 1 pint of acetone or lacquer thinner in to your car’s gas tank. Rotate the tank thoroughly by hand for several minutes and drain the remaining gas and residue. Dispose of the tank scum according to environmental guidelines.
Step 4 - Rust Removal
Clean the interior of the tank by putting several pieces of drywall screws inside the tank. Shake the tank thoroughly for several minutes, then add another pint of acetone or liquid thinner and shake the tank once more.
Step 5 - Sand your gas tank
Sand the exterior of your tank to remove unwanted build up and smooth out the surface to prepare it for the sealing process. Once your tank is completely clean from inside out, rinse it well and let it dry entirely.
Step 6 - Tape up
Place some duct tape or masking tape over the holes, joints or leaky areas to prevent the sealer from oozing out of the tank.  Apply putty to close up the outlet ports.
Step 7 -  Seal the Filler Holes
Use rubber bands and plastic wrap to shut the filler holes and avoid unwanted sealer and putty from dripping out.
Step 8 - Seal the Tank
Mix two parts of the Epoxy Sealer together for several minutes then pour the mixture into the tank. Make sure the sealer coats the interior of the tank completely, by rotating the tank several times. Take away the plastic wrap, dispense excess sealer and let the tank drain.
Step 9 - Final Clean up
Use a dull knife to remove excess sealer and putty then let the gas tank cure overnight.
Step 10 - Double Check
After the gas tank has cured overnight, visually check it for any possible unsealed holes. Double check it by simply applying air compression to detect leaks.
Step 11 - Reinstall
Finally, reinstall the tank to your car or vehicle. Make sure every screw is properly tightened and secured. Fill the tank with gas and you are ready to go.
 forum activity
