Gas to Wood Fireplace Conversion: Mistakes to Avoid
Converting a gas to wood fireplace is becoming popular nowadays because of the convenience that it offers to homeowners. Gas fireplace provides the appearance of a real fire minus the hassles involved when using a wood fireplace. An authentic fire appearance can be easily achieved by simple turning on the flame whenever it is needed. Aside from a convincing fire appearance that gas firewood offers, it also provides unique charm to its users. Nothing can beat the experience of seeing an amazing and crackling fire during cold nights. Also, by simply sitting by the gas fireplace, homeowners will be treated to a marvelous experience of smelling the burning wood which can also be therapeutic for some. Using wood fireplace is also good because of the material that it needs to function. As compared to gas fireplace which uses fossil fuel such as propane and natural to light up, wood fireplace uses wood which is a form of energy that can be renewed. Fossil fuel on the other hand cannot be renewed. Hence, for people who are thinking of ways on how to sustain resources for their fireplace, wood fireplace is an ideal option.
Mistakes to Avoid
Converting gas to firewood places should be done accurately to prevent any accidents from happening that may harm people and damage properties. Here are fireplace installation mistakes that should be avoided to ensure the safety of everyone in your home:
Getting a Permit
Checking with the local building regulations and getting proper permit for converting gas to wood fireplace should be kept in mind. There are rules and regulations to be followed when installing fireplace and making the conversion. It is vital to check with your local building code office to find out if you meet the required specification for converting your gas fireplace.
Professional Advice
In some cases, homeowners do not inspect the chimney carefully. Hence, they overlook the importance of seeing if the chimney needs to be lined up by a professional.
Flue of the Fireplace
The flue has an important function because it draws fumes and smokes from within the fireplace. If the flue has not been installed properly, toxic gases from wood fireplace may go inside your home. According to studies, the ratio of death between smoke inhalation and burn is 2:1, meaning for every 3 victims of fire, 2 die from smoke inhalation and one from burn. Additionally, around 60 percent to 80 percent of fire victims die from smoke inhalation. It is highly encouraged that you have your flue and chimney be checked by a professional.
Using wood fireplace has lower risk as compared to gas fireplace because it can be easily turned on or off if needed. Moreover, with gas fireplace, the possibility of having a gas leak is always there which may result to fire and claim lives and properties. And between the 2 fireplaces, wood fireplace is more eco-friendly because the process of wood combustion does not cause pollution. On the other hand, combustion of gas causes more risk to the environment.
In conclusion, converting gas to firewood offers more advantages. However, it is extremely important to do it with care to avoid any accidents from happening. The foremost concern for fireplace users should always be the safety of everyone.
