Login Error
Close
Gas vs Electric Weed Eater
by DoItYourself Staff
When purchasing a weed eater, you want to make sure that you get a quality model. You will have to decide whether you want to purchase a gas or electric weed eater. Here are a few things to consider about each type of weed eater.
Power
One of the big differences between these two types of weed eaters is the amount of power that you can expect to have. As a general rule, gas weed eaters are going to be more powerful than electric. This will help you cut through bigger and taller weeds then you will be able to with an electric model. It will also help speed up the process of completing your weed eating.
Ongoing Costs
One of the major advantages that the electric weed eater can provide is that it will be cheaper over the long run. In order to provide power to electric weed eater, all you have to do is plug it into its charger. Then, whenever you need to use it, it will be charged up and ready to go. With a gas weed eater, you will have to continually purchase gasoline and oil for it. Therefore, over the years, these costs can really add up.
 forum activity
