A gauge is system generally used for determining the diameters of circular, firm material. The Brown and Sharpe wire gauge is an accepted standard for determining the diameter of wires used for conducting electricity.
- The gauge of a wire has a direct bearing on the amount of current that it can safely carry across for the intended use in powering our gadgets.
- The gauge tables show that the wire diameters are reduced as the gauge of that particular wire is increased. The gauge of a wire can be machined by using the malleable nature of metals.
- This allows the operator to compress the wire to the desired gauge for use in different electrical applications.
How Does the Gauge of a Wire Affect Your Do-It-Yourself Project?
- While undertaking house wiring as a part of your DIY project, you have to pay particular attention to buying the wire with the correct gauge rating.
- If the gauge of the wire is not sufficient for your needs, the electrical connection can be compromised as there will be frequent breakages in the wiring that you install.
On the other hand, if the gauge of the wire is more than what is required, your gadgets could be damaged in case of a current surge.
Questions of a Do It Yourself nature should be submitted to our
