Login Error
Close
Geothermal Heat Pump vs Air Heat Pump
by DoItYourself Staff
A geothermal heat pump is an excellent way of heating your home while still reducing your carbon emissions. An air source heat pump is also a great item which can help you to achieve the same goal. Although both of these devices have a lot of advantages, there are also a number of reasons why you might decide to prefer one above the other. In choosing the geothermal heat pump or the air source heat pump, you will be deciding on what kind of device you feel has more to offer your surroundings.
Cost
When you are deciding between these two types of heat pump, you should definitely look at the cost. This is particularly important when it comes to the geothermal unit, as this will have a lot of labor and installation costs which might not be so heavy with the air source. Geothermal units come with a tax credit available from the national government, which helps to make the initial expenditure much less.
The air source heat pump has a disadvantage in that it is not very well known, and people are not sure what to expect from the device. While the pump is so little known, it is not surprising that there is still a large price on its initial purchase, which can prevent many people from considering it to be a good buy. This includes government agencies, who may be less willing to offer tax credits, discounts, and another advantages for an air source pump than for the geothermal heat pump, which is widely recognized. This can cost you dearly when it comes to making the initial payment.
Efficiency
Both the air source and the geothermal heat pumps are almost in the top of the class for their ability to reduce the amount of fuel that you need to burn to get your home completely warm. Air source heat pumps can save you around 40 percent in fuel bills alone, and that looks very pleasant on paper. Geothermals are around the same amount when it comes to savings on certain types of heating, although you may find that there is a more consistent production of heat from the geothermal than from the air source, depending upon the strength of wind as the latter does.
Environment
Both of these sources are considered to be environmentally friendly, using as they do the natural heat from the Earth as their source. Geothermal units tend to be slightly larger, per amount of fuel used, than the air source, and may also need to have a lot more digging and earth removal before a good thermal layer is found. This can affect the environment negatively.
The air source heat pump requires a large block which is the pump's catchment area, and this can make the surrounding area look unattractive. It can also be unwieldy, so you may find that you prefer the shape of the geothermal unit, despite the need for greater digging.
 forum activity
