Login Error
Close
Go Green in Your Bathroom
by Murray Anderson
It's hard to believe but in many homes one of the smallest rooms is one of the worst when it comes to wasting energy and natural resources. While it may not be a surprise to learn the average bathroom uses most of the water in a home, the fact a lot of that water is being wasted may be. It's not just water however, a lot of the energy used to heat that water is also going to waste. If you'd like some ideas on how to save some money as well as make your bathroom more eco friendly, here's how you can "go green in your bathroom".
Toilet
  • Toilets account for around 30% of the water use in the average home so anything you can do reduce water use will save you money.
  • A toilet that runs constantly is just water running right down the drain. Repairing a running toilet is a relatively easy project with replacement parts readily available at your local home improvement store, - often along with printed instructions on how to remove the old,defective parts and install the new.
  • New dual flush toilets use different amounts of water depending on whether you're flushing solid or liquid waste. Solid waste uses a full 1.8 gallons while a liquid waste flush uses only .8 gallons.
  • Don't have the money to spend on buying and installing a new dual flush toilet? Fill a family sized plastic pop bottle with sand and place it a corner inside your toilet tank. The bottle will displace water when the tank fills, so there's less water in the tank when the toilet is flushed so less water is used. (Not quite as elegant as a dual flush toilet but definitely a water saver on every flush).
Shower
  • Installing a low flow shower head in your shower will save both water and energy. Conventional showerheads use 4 to 6 gallons of water per minute while a low flow shower head will easily reduce that by at least half (and new technology means modern low flow showerheads have the same "feel" as conventional heads).
  • Not only are you saving water with a low flow shower,  think about your energy savings by cutting down your hot water usage (hot water is usually 25% or more of a home's energy usage).
  • If you're willing to change your habits a little you can save even more water and energy. Install a low flow showerhead with a shutoff valve. The valve allows you to shut off the water while soaping up, then just turn it back on to rinse off and not worry about adjusting the temperature.
Basins
  • It's easy and quick to install an aerator on most bathroom faucets and aerators are available that can reduce the water flow to as little as .5 gallons per minute. Just think about the water (and energy) savings a low flow aerator can generate.
  • Here's a simple trick - turn off the water while you're brushing your teeth. Most people don't and the running water is simply being wasted.
Murray Anderson is an experienced freelance writer whose work has appeared on numerous web sites, as well as in newspapers and books  in both the US and Canada. He is often cited as an expert on home related topics and is a regular contributor to DoItYourself.com.
 forum activity
