Login Error
Close
Going Green: Advantages to a Natural Cork Floor
by DoItYourself Staff
Natural cork floor has become popular in recent years, and there are many different variations of this flooring available. This type of flooring provides several benefits, including eco-friendliness, durability and natural qualities that repel insects.
Environmentally Friendly
One of the biggest advantages of purchasing a natural cork floor is that it is environmentally friendly. When you buy this type of floor, you will be doing your part to help the environment. Cork flooring is created by taking the bark off of a cork tree. Manufacturers do not have to damage the tree in any way when they are harvesting this material. This means that it is sustainable and is not negatively impacting the environment in any way.
Quiet
Another big advantage of installing natural cork floor is that it is quiet underfoot. This type of flooring is much quieter than hardwood, laminate or tile. When you walk on it, the cork will absorb most of the sound from your shoes. Many people hate the loud sound that comes with laminate or hardwood, and this provides you with a similar alternative to work with that is much quieter.
Natural Insulator
The nature of cork makes it a great natural insulator. When you put this on your floor, it will keep the cold air from the subfloor below out of your house. When you are trying to heat or cool the house, it will help keep the air in. This can significantly lower the amount of money that you have to pay in utility bills over the course of a year.
Naturally Repels Insects
Another big benefit of going with this type of flooring is that it naturally repels insects. You will not have to worry about termites or any other type of bug getting into the cork. Instead, you can rest easily knowing that the cork will prevent others from coming around.
Cleaner
This type of flooring is also cleaner than many of the other options that are available. This flooring is actually antimicrobial so it will not support the growth of bacteria. It is also not very susceptible to mold or mildew. If you have ever had carpet, you may know that mold or mildew can grow underneath the surface in the pad. With cork, you can clean up spills easily and it will not soak down into the flooring. This makes it much easier for you to keep your flooring clean and free of any bacteria or mold.
Durable
Cork flooring is also very durable. This type of flooring can withstand a lot of wear and tear and it is resilient. If it is dented, it will generally resume its natural shape after a certain amount of time. It is also fire resistant and it will not rot like some other types of wood can when they get wet. This makes it one of the most durable flooring options that is available.
 forum activity
