Going Green: How to Fill a Chip in Tempered Shower Glass
what you'll need
- Safety goggles
- Safety gloves
- Glass repair resin
Tempered shower glass is known for its durability and as an enhancer to the beauty of the bathroom. They make bathrooms look bigger. They are also not hard to clean at all.
Tempered glass is a strong material but there are instances when it could get cut or chipped. When this happens, you must fill in the chip right away so as to avoid bigger problems with the glass. The internal stress becomes unbalanced when the glass chips. This compromises the strength of the entire glass pane. The good news is that you can do this on your own by following a few simple steps.
Step 1: Repairing the Shower Glass
Tempered glass is a bit difficult to deal with since it can explode if it gets chipped. If the chip is not that big, you can go without replacing the glass and using a glass repair resin instead. This is a thin solution that fills in the chipped part of the glass.
Step 2: Tempered Glass Safety Tips
Remember to always wear safety gear such as goggles whenever you work with tempered glass. Safety gloves are also a must so that you will be protected in the event of a break.
