Login Error
Close
Going Green: How to Install a Single Point Tankless Water Heater
by DoItYourself Staff
what you'll need
  • Pliers
  • Side Cutter
  • Working gloves
  • Water Filter
  • Drill
  • Hammer
  • Pipe Clip
  • Screw Driver Set
  • Tankless Water Heater Set
  • Circuit breaker
  • Electrical Wires
  • Electrical Tape
  • Copper Pipe and Fittings
  • Braided Steel Flexible Connectors
A tankless water heater is energy efficient and may help you save a lot of money in the long run. There is a number of tankless water heaters now that have specific models built depending on your basic needs. For shower heaters, some models no longer require isolation of the heating unit from the shower unit. This provides easy access especially on models that have the option for a variable temperature setting mode instead of the manual (mixing two knobs: one knob for hot and another for cold) method while taking your shower. The former may require you to only maintain a single water source while temperature is adjusted using the temperature setting on the heating unit itself.
If you want to install a tankless water heater as replacement for your existing tank water heater for your bathroom shower, the following steps will help you.
Step 1 – Get the Work Area Ready
Bring the materials to a working table which is setup on the bathroom area. Keep any wires or conductive materials away from the workspace. Take extra precaution especially on the electrical connections. Ensure the electrical main breaker is turned off.
Step 2 – Install the Electrical Connections
Check the nearest electrical junction box and connect a pair of electrical wires into it and attach the other side to a set of circuit breaker. The circuit breaker is important especially if the tankless water heater is going to draw around 48-amperes of current from the electrical source. This will ensure that the electricity is cut off in case of emergencies. Route another pair of electrical wires from the circuit breaker to supply the water heater set. Use electrical tape for the termination of connected wires.
Step 3 – Uninstall the Existing Heater Pipeline
Close the main water source valve of the shower. Remove the existing heater pipeline (from tank heater unit) and clean up the area.  Put up fittings to connect it into the cold water input of the tankless water heater.
Step 4 – Install the Main Tankless Heater Unit
Locate the position of the shower unit inside the bathroom or at a designated cabinet. Mark desired position and drill holes. Fix the tankless heating unit into the wall. Install braided steel flexible connectors from the water source main valve and attach a new connection towards the cold input fitting of the tankless heater unit. Connect another braided steel flexible connector towards the “hot water” connector of the shower head. Secure the flexible connectors in place using pipe clips secured into the wall.
Step 5 – Finishing up
Test the setup by switching on the circuit breaker and switching on the tankless heater unit. Adjust the “hot” valve and mix with the “cold” valve of the shower controls. When everything is working smoothly, proceed to clean up the working area and put away all the tools.
 forum activity
