Login Error
Close
Granite Countertop Repair: 5 Mistakes to Avoid
by DoItYourself Staff
Granite countertop repair is harder than it should be but they are expensive to replace, making replacement out of most budgets. Granite conveys success and enhances any area it is in. Granite is a very hard substance which makes granite countertop repair unusual but sometimes it may happen. There are things to take into consideration when taking on granite countertop repair regardless of the damage. The article that is found below will share with you several mistakes to keep in mind when doing this job so you do not have to replace the granite countertop.
1. Removing the Finish
When you start to do granite countertop repair you will notice that the granite is often covered with a finish of some sort. This can be polyurethane, wax or other finishes. If you try to repair granite countertops but fail to remove the finish then the repair job will most likely not work. This includes filling gash marks and removing stains. The finish is easy to remove by using a sander and 120-grit sandpaper. Once the area is dull and somewhat white you know the finish has been removed and the repair can then be started. Just keep in mind that you should then refinish the granite so it fits in with the remaining counter space.
2. Flaking Granite
When granite is chipped or scratched you should never just fill and repair or sand it down. What you may not realize is that when damage occurs it will leave loose stone in its wake. In order to get a great repair you should always brush away any loose granite. A soft brush, like a toothbrush, can easily remove the loose rock. Once the loose pieces are gone you can commence with the repair.
3. Vinegar as a Cleaner
There are many things that can benefit from using vinegar as a cleaner as it is very good at removing stains and sterilizing an area. Using vinegar on granite can actually damage the surface and not help it. If you plan to use all natural ingredients to clean off scuffs and stains do so without using vinegar.
4. Harsh Chemicals
Vinegar is a natural cleaner that can damage granite, defeating granite countertop repair efforts. The same can apply to other chemicals found at most stores. They can remove the finish on the granite as well as etch the rock. Some will even stain the surface. This happens because they often contain some form of acid. Keep it simple by using soap and water and a little elbow grease when removing scuffs, and even some nicks can be removed in this manner. These include surface scratches.
5. Divots
This type of damage is fairly common as small chunks of granite can be chipped away. This type of granite countertop repair is often thought to be very difficult but it really is not at all. The easiest repair is to use epoxy to fill the gash. Once the epoxy dries it will be fairly unnoticeable. Over thinking the repair often leads to more damage.
 forum activity
