Login Error
Close
Grease Stain Removal
by DoItYourself Staff
There have been many solutions for grease stain removal. Some of the tips work, others do not. It really depends on how quickly you begin the grease stain removal process and how much elbow grease you put into it.
If you begin the grease stain removal process right away, your chances for success are much greater. You should blot any excess liquid from the material first with a clean dry towel. You can use many different methods and solutions for grease stain removal, but the one that seems to work best is:
• 1 Cup Cold Water
• ¼ Cup Dawn Dishwashing Detergent
The grease stain removal agents in the Dawn will help to work the stain out quicker.
Laundry Grease Stain Removal
Using the solution above, create a paste and rub in to the garment. You can use a gentle brush or simply rub the clothing against itself to create the scrubbing friction. You should allow the grease stain removal solution to set on the clothing for 30 minutes before washing.
Always check to ensure your grease stain removal has worked before placing the item in the dryer, the heat will set it in forever.
 forum activity
