Login Error
Close
Great Tips for Using Rust Cleaner
by DoItYourself Staff
A rust cleaner effectively and safely removes rust from a variety of surfaces. This product is not too difficult to use and, by using the tips below, you can efficiently remove rust without too much trouble.
Consider Materials
You should look for a rust cleaner made specifically for the kind of material the rust has gathered on. There are different products available to clean rust from a variety of materials including cement, chrome, steel, brass, fabric, and many others. You can also find combined products that can clean rust from any surface.
Follow the Directions Closely
Always follow the directions provided on the cleaner bottle. Some rust cleaners can be corrosive and handling them properly ensures your safety and prevents damage to your other fixtures.
Wash the Area
It’s a good idea to clean the area that is rusted before applying any kind of rust cleaner. This will eliminate any other dirt that may have built up and make the rust cleaner much more effective.
Try Homemade Products
Before you invest in a rust cleaner, you may want to try some home remedies first to save some money. A pumice stone will generally remove rust from bathroom fixtures and cement. Lemon juice and salt in some tepid water may help to remove rust from clothing or other fabrics. You can also try using Coca-Cola and baking soda. With all of these homemade alternatives, be sure to test the solutions on a small spot of the rusted area. You want to be sure it's effective at taking the rust off.
 forum activity
