Green Approaches to Remodeling Your Kitchen
Remodeling your kitchen can be an exciting project. Fortunately, you can remodel your kitchen in a manner that can cost you less money and make less of an impact on the environment. Follow the tips below to make your kitchen remodel an environmentally-friendly project.
Sustainable Materials
If you’re buying new cabinets and flooring for your kitchen, look for items that are made of sustainable materials. This is especially important with cabinets and floors made of wood because it helps stops the deforestation of the planet. Such items should be marked as sustainable. You might have to look a little harder to find them and go beyond normal hardware stores. These features may cost more upfront, so finding and installing them requires a commitment to a green remodel.
Energy
A remodel is an excellent time to look at your energy sources. You can cut your electric bills by using solar power to supply some of your energy needs. You can buy and install a solar panel on your roof that can be hooked up to your water heater.
Another option is to consider fitting a wind turbine to your house, although this will depend on where you live. While you probably won't be able to supply all the electricity you need to run your house, every bit of saved energy counts.
Recycling
One green approach to remodeling your kitchen is by recycling old cabinets. You can also recycle flooring and appliances. This will save you money over buying new equipment ans well as reducing your personal carbon footprint. This is, however, a method that can present problems. First of all, you have to find cabinets that you suit the plans for your kitchen and they have to be in good condition. To install them, you may need to renovate or refinish them firs, so there’s likely to be plenty of work involved.
Appliances
Often, part of remodeling your kitchen centers around replacing your appliances, which offers up another green opportunity. Modern appliances use a lot less energy than older alternatives. They can also end up paying for themselves in a short time because of the energy they save.
You’ll need to do your research in order to find the most energy-efficient appliances that will best suit your needs. You should consider replacing your refrigerator and freezer as a priority as well as exporing all avenues regarding wasing machines and food waste management appliances. Replace as much as you can afford to as you’ll make significant savings in the longer term. Always check for the Energy Star mark.
By applying several green approaches together when remodeling your kitchen, you can have a very eco-friendly final result.
