Login Error
Close
Green Chemical Cleaning after Termite Tenting
by DoItYourself Staff
Chemical cleaning is a process necessary after termite tenting. Although some people say that chemical cleaning is not necessary after the termite fumigation process, it is a safety procedure that will ensure that every treated surface is free from harmful chemicals. Since chemicals from the termite tenting process may have negative effect on metals and other surfaces, it is necessary to clean the chemicals with natural cleaning agents. Here are some of the most common natural cleaning agents that can be used for green chemical cleaning.
Vinegar
Vinegar is a good cleaner for plastic or metal surfaces. To use vinegar as a cleaner, a spray bottle is necessary. The recommended solutions is one part water to one part of vinegar. Mix the two in a spray bottle and use it to spray metal or plastic surfaces. Vinegar can also be used to clean the stains on the metal and plastic surfaces as well.
Baking Soda
Another green product that can be used to wash off chemicals from surfaces of metals and plastics is baking soda. Baking soda can be made into a paste and spread on surfaces to remove chemicals, stains and other contaminants. To use baking soda, simply mix it with water to create a paste and spread it to a metal or plastic surface. Let it sit for 30-minutes and clean afterwards.
Detergent
Green detergents work very well in cleaning chemicals from surfaces of walls, metals, plastics and other materials. Simply use detergent and water to wash off chemicals from surfaces and allow it to dry. The detergent will loosen the chemicals and wash them off with ease.
Alcohol
Alcohol is an organic compound that can effectively wash off chemicals from surfaces. Do not use denatured alcohol though since it is poison. Make sure to use isopropyl alcohol for chemical cleaning.
Alkaline Solutions
Alkaline solutions are also effectively used to wash off chemicals from surfaces after termite tenting. Alkaline solutions are used to neutralize acids as well as deodorize surfaces. When choosing alkaline solutions to clean chemicals, make use of types that are not harmful to the skin.
Cornstarch
Cornstarch is not only an effective chemical cleaner, but a stain remover as well. It can be used to clean and polish furniture, carpets, and rags. Let the cornstarch stay on the affected areas and let it sit for a few hours before vacuuming.
Water
Water, the universal solvent, is probably the most effective chemical cleaning agent. It can effectively wash off chemicals from many types of surfaces such as metal, plastic, and wood. Use it with lemon or vinegar to clean glass surfaces. Use it with detergent to clean floors, plastic and metal containers, as well as other materials. Water is probably the safest liquid to use when washing off chemicals.
Chemicals used in killing termites are not only fatal for termites, but for humans as well. In order to ensure that the inhabitants of the house are safe from chemicals, make sure to make use of safe products to wash them off or remove them from the house.
 forum activity
