Login Error
Close
Green Detergent for Your Pressure Washer
by DoItYourself Staff
The best pressure washer detergent to use is green detergent, especially when going green. Green detergents are eco-friendly and prove to be effective cleaners as well. Green detergents are made up of mild form of soap and chemical agents that turn into a biodegradable material when get mixed with water, and do not leave harmful chemical residue to any surface.
Choosing the best pressure washer detergent is a very important thing when using a pressure washer. Detergent allows the washer to easily loosen dirt, stains and other contaminants such as molds and mildew. Stains and molds are very difficult to remove even when using a power washer. However, if an effective power washer detergent is used, then the cleaning process will definitely be easier.
Liquid and Power Pressure Washer Detergent
Liquid detergents are usually packed in concentrated forms and are placed inside ready to use bottles. Powder detergent is usually packaged and needs to be dissolved in water before use. The pressure washer detergent can be applied directly on the surface to be cleaned or can be sprayed as well. It can be applied prior to using the pressure washer or during the cleaning process. Manufacturers’ provide the proper dilution proportions so make sure to follow instructions before proceeding.
Where to use Pressure Washer Detergents
The detergent can be applied to many different surfaces. Windows, bricks, vinyl sidings, garage doors and concrete walls can be cleaned using pressure washers and detergents. Pressure washer detergents can also be used to clean fences and gates made of metals. Vehicles, driveways, walkways and house sidings can also be cleaned effectively with washers and detergents.
Making a Home-made Pressure Washer Detergent
The detergent can also be made easily using simple ingredients. To clean molds and mildew that is growing on concrete or wooden surfaces, it is important to add bleach to the detergent. This ingredient will clean the stains on the surfaces effectively.
To make detergent 1/3-cup laundry soap, one quart of liquid bleach, 2/3-cup of powdered cleanser and a gallon of water will be needed. In addition, a big bucket will also be used. Simply mix all the ingredients well in the bucket slowly. Make sure that the ingredients are mixed very well to ensure that there are no suds afterward.
Since bleach may not be good for plants, it can be removed from the mixture. Use it only as an option when deemed necessary, especially when cleaning hard-to-remove stains. Since chlorine bleach is hard on color and stains make use of oxygen bleach instead. The bleach will definitely remove the molds and mildew from the surfaces. When using water only, some of the mildew and molds may be removed but not entirely.
How to Apply the Detergent
When cleaning surfaces follow these stepss: pre-wash the surface with hot water and then apply detergent. The hot water will loosen hardened stains from the surfaces. Afterward, spray the detergent and allow it to sit for a few minutes first before using the pressure washer. Add more detergent if necessary.
 forum activity
