Green Home Improvements: 5 Remodeling Options
A green home is a house that is designed to be environmentally friendly. It is a property that focuses on the efficient utilization of building materials, water and energy.
Green home remodeling has been increasing in popularity as many homeowners find ways to improve the resilience and appearance of their houses. Green home improvements, like bamboo flooring and the like, offers favorable as well as long-term enhancements to sustainable houses. Green home remodeling has been described as eco-friendly and trendy.
Below are five popular remodeling options that you can consider in making green home improvements.
1. Adding Insulation that is Energy Efficient
Adding insulation that is energy efficient can result in a significant positive impact to the environment and on your pocketbook. It can also raise the energy efficiency of your house a considerable degree. Additionally, this kind of insulation will help prevent rotting, as well as keep you warmer in the winter and a little cooler in the summer. This type of remodeling option is best for old homes which normally don’t have enough insulation. Install this green home insulating product in the attic, in the ceilings or in the wall.
2. Installing Solar Energy Roofing Panels
These will produce electrical power for your home and solar panels can be considered trendy as well. This type of roofing panel gives a more modern look to every house that has them. Plus, you might be able to get a rebate when you purchase them. Some states encourage the use of solar panels by giving homeowners who use solar panels a rebate. You can also save money on your electric bill. Aside from solar panels, you can also check out solar roofing shingles, a solar panel that is attached to the main metal roof.
3. Installing Power Saving Lights
LED (Light Emitting Diode) lights are not only energy saving, they are long lasting as well. Installing these types of lights as a replacement for your conventional fluorescent and incandescent lights will give your house a lighting system that’s hassle-free (bulbs do not need to be replaced) and that lasts for a very long time. Compact fluorescent lights, like LED lights, are also energy saving in the sense that it can provide a lot of light for little or no additional cost. These types of lights provide more illumination for a room than the conventional incandescent bulbs, for almost the same amount of energy consumed.
4. Installing Green Flooring
Installing bamboo flooring or any green flooring product will not only add to the aesthetic appeal of the house, it will also contribute to its eco-friendliness by using renewable resources. Aside from bamboo flooring, there are also other types of green flooring, all readily available in stores.
5. Installing Energy-Saving Windows
Installing energy-saving windows can help cut costs on electricity bills, as they act as a sort of natural air conditioning system for your house. These windows allow the sun’s heat to make the room warmer in winter and keep it cooler in summer. Installing energy-saving vinyl siding can raise the energy efficiency level of your house, as well as provide for an artful decoration. You can also choose to install metal wall panels, which provide the same excellent advantages as vinyl sidings but provide a different look and feel for your green home.
