Login Error
Close
Green Methods of Ceramic Tile Cleaning
by DoItYourself Staff
When it comes to ceramic tile cleaning, there are a number of different methods that you could potentially use. Some of them will involve harsh chemicals, and some of them are safe for the environment. Here are a few green methods of ceramic tile cleaning that you can implement.
Vacuuming
When it comes to removing the dust and dirt from your tile floor, you might want to consider using a vacuum cleaner. There are many different vacuum cleaners on the market that have ceramic tile attachments. This allows you to suck the dirt up off of the floor without using any cleaners at all.
Mop With Water
One of the simplest and most environmentally friendly methods of cleaning ceramic tile is to mop it with water. By doing this, you will not be using any harsh chemicals, and you will still be able to clean the floor. If you use this method, you should be able to remove anything that was spilled on the tile as well as all of the extra dirt and dust.
Soap
In addition to mopping with water, you can also add some soap into your mop bucket. Using dish soap can be a good way to add a little bit of extra cleaning power to your mop water. Dish soap is very mild and should not do any damage to your tile or to the environment.
Vinegar
Vinegar is an item that most people have in their households already. It is also a very powerful cleaning agent that can disinfect as well. Take some vinegar and mix it with water in order to form a powerful cleaning agent for your ceramic tile. Using vinegar is a good idea because it will not discolor the grout in the tile like some other cleaners would. You can play with the mixture between vinegar and water to find the right ratio for you. Many people start out with one part vinegar and 10 parts water in their mop bucket. Even though it might smell strong, the smell will generally go away within a few minutes.
Steam Cleaning
One of the most powerful ways to clean your ceramic tile and the grout is to use steam cleaning. For this process, you may need to hire a professional cleaning company to do the job for you. Many of these companies have a high pressure steam cleaner that is designed to clean the grout lines. With this method, steam will be forced down into the tile and grout with high-pressure. This is perhaps the most effective way to clean grout that is currently available. Many people report that their grout reverts back to its original color after utilizing this technique. You can also rent or purchase a steam cleaner that you can use for this application if you do not want to hire someone to do it for you. However, it is often cheaper to let someone else handle it for you.
 forum activity
