Guest Room Basics: A Clean Bathroom Makes Happy Guests
If you'll be entertaining overnight guests in the near future, it is imperative that your guest room bathroom be clean. A clean bathroom can make your guests feel like they're at a four star hotel, whereas a dirty bathroom is liable to make them wish they had stayed home.
Clean Your Toilet
Begin by cleaning your guest room bathroom's toilet. This is typically a simple matter of spraying your toilet bowl will a commercial toilet cleaner, allowing the cleaner to sit for several minutes, then using a hard-bristled toilet brush to purge any caked on dirt or grime. Also, take care to use a sheet of toilet tissue to wipe any dust off the rim of your toilet bowl.
Clean Your Bathtub
When cleaning your guest room bathroom's tub, you will need to spray it down with a tub and shower cleaner, allow the cleaner to set in, then use a sponge, washcloth or scrub brush to lay waste to any grime. If your tub has trace amounts of mold or mildew, spray the affected areas with a commercial mold and mildew cleaner, then wipe it away with any of the above mentioned cleaning tools. Repeat this process until the tub is free of mold and mildew.
Clean Your Sink
Lastly, you will need to clean your guest room bathroom's sink. Begin by thoroughly wiping the sink down with an absorbent paper towel. Next, spray the sink with an all-purpose cleaner, allow the cleaner to set in, then use a sponge or washcloth to wipe the sink clean.
