Login Error
Close
Guide To Installing Skirting
by DoItYourself Staff
what you'll need
  • Vinyl skirting
  • Level
  • Shovel
  • Hammer with nails
  • Screwdriver with screws
  • Tin snips
Curt M
After your mobile home is installed, you’ll need a short guide for installing skirting to add a finishing touch. Skirting added to your RV or mobile home will help retain heat during the winter, add an extra dimension of storage as well as improve the aesthetic look to your home. This do-it-yourself project is fairly easy to complete following some simple instructions.
Step 1 – Obtain a Skirting Kit
If you live in a mobile home park, check with your neighbors where they purchased skirting for their homes. It is available at almost every home improvement center or local building supply store. The skirting usually comes in a kit with enough J channel to completely surround your mobile home accompanied with both solid and vented skirting pieces. The kit also contains U channels to secure it to the ground and corner channels along with the necessary screws and long spikes needed to successfully install the skirting.
Step 2 – Install J-Channel
Secure the J-channel to the bottom edge of the building screwing it directly into the building studs wherever possible.
Step 3 – Plumb the Corners
Make a mark at each building corner using a level or plumb bob to ensure each corner will be level.
Step 4 – String It
Place string from corner to corner to mark placement of the bottom U-channel.
Step 5 – Level Surface
Use a shovel to level the area removing all debris. Also, use the shovel to grade the area so water will drain away from the building.
Step 6 – Install U-Channel
Install the U-channel along the string line securing it to the ground using long spikes.
Step 7 - Install Corner Channel
Select a corner where you will start and install a corner channel.
Choose a corner from which to start, and install a corner channel there.
Step 8 – Measure Height
Take the measurement of the height between the U-channel and the J-channel. Add an additional half inch on each end panel that will be hidden.
Step 9 – Cut Panels
Once you’ve secured the measurement, cut a panel using the tin snips.
Step 10 – Snap the Panel
Now snap the panel into the J- and U-channels. Repeat the process for other panels remembering to place a vented panel after every two or three regular ones. Continue until the entire building is skirted.
Things to Remember
  • Don’t hesitate to either select or prepare to finish your skirting to enhance the look of your home and property. The vinyl skirting is available in different colors. Also, instead of vinyl, you may wish to use faux wood or faux stone as a substitute.
  • It is a good idea to install an access door somewhere along the skirting so you can use the under space for storage.
  • In some areas where wind is a strong factor, a good idea would be to first construct a frame to provide better stability.
 forum activity
