Login Error
Close
Gutter Helmet Basics
by DoItYourself Staff
A gutter helmet is a hood that fits over your gutter to prevent leaves and debris from accumulating in the gutter and blocking water flow. A gutter helmet should be designed to block solids from entering while allowing water to pass through. To get the best results make sure you purchase a gutter helmet that is compatible with your roof and your gutter type
Gutter Helmets Types
Screen gutter helmets allow water to pass through while blocking larger debris in. More solid types of gutter helmets are available that keep the entire gutter free of debris, but they may also prevent water from entering the gutter. A common problem with gutter helmets is the buildup of leaves and debis behind the gutter hood. While a gutter helmet will save you the trouble of climbing up on the roof to clear the gutton after every storm, sooner or later you may still have to climb a ladder to clear out the debris that builds up between the gutter and the shingles.
Gutter Helmet Installation
Installing a gutter helmet yourself can be as simple as snapping some parts into place or complicated enough to require the help of a professional. Some gutter helmet options are capable of simply being snapped on or snapped in, while others require a more lengthy installation process.
 forum activity
