Login Error
Close
Having Your Indoor Air Quality Tested Accurately
by DoItYourself Staff
Your safety is the primary concern when having your indoor air quality tested. Indoor air quality can be affected by dust mites, mold, mildew, carbon monoxide, radon and other airborne pathogens. By using the following tools and tips, you can test your home’s air quality accurately.
Carbon Monoxide and Radon Detectors
Carbon monoxide is a byproduct of a furnace that requires maintenance or replacement. The detectors test the air to sense any change in levels of this gas in your home and will sound if it is at an unsafe level.
Radon is produced due to high concentrations of uranium in the soil. The kits test for radon levels over a period of three days and are then mailed to a lab for analysis.
Mold and Mildew
A test kit for mold and mildew determines their levels within your home. They have easy to follow directions and once they are completed, you mail the kit to a lab for analysis.
Dust Mites
Dust mites are the most common problem with indoor air quality. A dust mite test kit includes a small vial for placing samples that you collect to mail to a lab.
Air Quality Solutions
Once you have received the testing results, you will need to implement solutions to these problems. For dust mites, installing special filters in your furnace and vacuum cleaners will remove them from the air.
For more serious issues such as radon or mold, you will need to hire specialists to help. Carbon monoxide issues can be solved by determining where the leak is and hiring a professional to fix it.
 forum activity
