Heat for Cheap: Electric Fireplace Buying Guide
Create instant ambiance by installing a cheap electric fireplace in your home. This reinvention of the traditional hearth is turned on with the flip of a switch and provides a quick source of heat along with the look and feel of a real fireplace. These portable, easy-to-install, maintenance-free fireplaces require nothing more than an electrical outlet to operate and enjoy. No venting is necessary. Consider the following features when shopping for a cheap electric fireplace.
Room Size
Measure the dimensions of the room in which you are going to place your portable fireplace before shopping. Consider both the space to be heated and the available wall space for placement. Then check the manufacturer's specifications on different brands and models to select the right size. This is especially important if you will be relying on the fireplace for heat rather than just ambiance.
Construction and Energy Efficiency
You will want to ensure that the fireplace you choose has solid construction and sound workmanship. The more features designed to increase efficiency make the fireplace more valuable. Realistic looking flames are another measure of quality. Thermostat controlled. Glass remains cool to the touch
Design Style and Features
The range of available design styles and materials is comprehensive enough to complement any decor. Styles include rustic, contemporary, craftsman, Regent and Amish. Corner units, freestanding units and units that are designed to accommodate TVs and bookshelves make electric fireplaces a practical choice as well.
Price Range
Electric fireplaces vary in cost from around $200 to upwards of $1000 or more for upper-end models with more realistic flames, larger heating capacity and more intricate workmanship. You will find many options to choose from that will satisfy your style, space and budget.
Room Size
Price Range
