cancel
Job type :
Zip Code :
community forums
comments
Heating Furnaces
Heating furnaces are the vital component of a central heating system. Heat furnaces are typically "forced-air" units that suck in air through a filter, heat it, and blow it out through air ducts in ceilings or floors. Heating furnaces are controlled and regulated by a wall-mounted thermostat.
Types of heating furnaces
With gas-powered heating furnaces, a gas and air mixture travels into the burner and is lit by the pilot light. Warm air from the burner flame fills a chamber called a heat-exchanger, which warms the surrounding air. The warm air goes into the air ducts and is carried throughout the building.
Electric heat furnaces generate heat via an electric heating element. Electrical currents travel through the element and generate heat. The heat transfer processes of conduction and convection allow heat furnaces to transfer heat into the air currents that flow through air ducts and into a building.
Maintenance of heating furnaces
There should be no black soot or combustion residue on or around heater furnaces. Burner flames should be blue and consistent as opposed to yellow/orange and flickering. After cooling heating furnaces and turning off the circuit breaker that powers them, remove the furnace sides and vacuum up any dust. Also clean the blower blades of heater furnaces with a damp cloth, and fill any blower fan oil cups with a few drops of oil. Check the condition and tension of any fan belt, and change the filter of heat furnaces each month of the heating season.
Here is more useful information about heating furnaces.
member comments
posted Jan 12, 2009
I have moved into a trailor 2 months ago, I got the propane tanks filled and our furnace kicks on every 2-3 minutes and 24 days later we need more propane I set the thermostat at 68 degrees should I replace the thermostat and or insulate the home better? I have a very limited income
Did-it-myself Projects
updated by FelipeBR
did this on 9/22/2009
Iphone Bus Holder
updated by SolarPanel
did this on 8/29/2009
Home Build Solar System
updated by dorfin
did this on 3/30/2009
Recoil Starter Repair
Decorating For Thanksgiving
sponsored articles of the day
