Heating Vents: Size and Room Placement
Heating vents can come in very handy when you want to maintain the temperature of your home without having to spend a lot. This is an environment friendly way of controlling temperature and humidity; it is safe and healthy, and cheap as well. Just by cutting some corners not only do you help conserve natural resources but also save money.
Make sure that the vents are placed close to the floor. Hot air is lighter and rises quickly. If you have the vents near the floor then there is uniform heating all over the room. But make sure that the vent opens a few inches above the floor. This is because the bursts of hot air can cause floors to dry and crack, especially if they are made of wood.
Insulation Material Used for Heating Vents
Make sure the right insulating material is used for the vents. This is important from safety point of view as well. Using the right insulation also helps to cut down on heat loss and increases on the efficacy of the vent. For deciding on which material to use, look up the building code of your apartment or house. There are some very strict rules regarding the materials you can use and strict adherence to these rules is very necessary.
Something Interesting to Do with Your Vents
If you want to be a little adventurous, then you can use decorative vents which add to the appeal of your home. These are especially meant for areas like the living room. Decorative vents come in different designs and you can pick one which goes best with your house décor. The latest in heating vents is a magnetic vent. These are supposed to improve the efficacy of the heater by channeling the air flow and cutting off the flow when you don’t need heating.
Maintenance of Heating Vents
It is very important to maintain the heating vents properly. First of all, clean the vents regularly and also take a look at the ducts from time to time, in order to make sure that they are not blocked. Also get the insulating material changed from time to time to make sure that there is minimal heat loss. These are very small steps when it comes to maintaining the heating system of your home, but they go a long way in cutting down energy wastage and extra cost incurred due to this wastage.
