Home Alarm Systems: Do It Yourself Guidelines
Follow these home alarm systems do it yourself guidelines to protect your home and family. Read on to learn more about different types of alarm systems and how you can install one in your home.
Choosing the Right Alarm System
To begin, decide what you actually need in terms of effectiveness. Alarm systems vary in size and ability to a great degree, so it will help to narrow down the features you need before you shop.
The size of your home will be the greatest deciding factor in choosing the right alarm system. Your budget will also be a key factor in this determination. If you want top of the line protection then consider using either infrared alarm systems or ultrasonic systems. If low upfront cost and easy installation are what you're after, a simple magnetic alarm system or beam system may be all you need.
Central Command or No Central Command
Certain alarm systems will have a central command center that is contacted when an alarm is triggered. If an intruder comes into your home, the alarm sends a signal to the central command station. When this happens the central command sends out the appropriate response which can be to police officers or firemen. This type of service is typically a monthly or annual fee. You do not need this service if you are installing an alarm yourself or are not overly concerned with break-ins.
Wiring the Alarm System
One thing to look for in a home alarm systems do it yourself guide is detailed information on connecting the alarm system. There are several parts to consider when trying to follow some sort of guideline. If you want to hard wire the alarm system to your electrical wiring you will need a professional to do this for you. You can easily run power cables and coaxial cables through walls in order to string together cameras and monitors as well as a way to power them all. A very simple alarm system is one that is wireless in nature. Cameras can run off of batteries and they will transmit over your Internet service directly to a computer. You can then monitor the feed from the Internet or can record the information to your hard drive.
Placing an Alarm System
If you plan on wiring your alarm system to your home electrical then you will need to place them in places which have easy access to the wiring. You should place cameras wherever you have the most concern. This could include the outside of the front door, the entrance to the driveway or any side entrances of the home. Dark areas or blind spots are prime areas for criminals to gain access to the home and are perfect spots for your alarm system.
