Home Automation Lighting
Using an automated system to control the electronic aspects in you home can include home automation lighting. Home automation lighting systems can include switches, controls of natural lighting, and even a system which can cause the lights to come on and off even when the owner is not at home. If you are considering purchasing a home automation lighting system to install in your house, then you should take the time to consider the different styles of lighting, from switches to natural lighting, which can be operated by a home automation device.
Automated Light Systems
Home automated lighting does not have to be very complex or expensive. One of the most simple of the automated systems is the timer switch. This is used to operate a light at a particular time of day. The timer switch can also be used to turn on heaters, or morning coffee machines, so it is a very versatile device. More complex home automation systems include remote control lighting, which allows you to turn the lights in a room on and off without having to touch a switch on the wall. These lights are controlled using a keypad or touch panel located in the hall. This allows users to toggle lights on and off, control dimmer lighting, and program levels of lighting in particular rooms. This means that you can turn off downstairs lights from upstairs, for example, which can be useful when going to bed at night.
Automated home lighting systems are popular with those who have home theater systems, because a remote control can be used to turn the lights on and off, or control a dimmer switch. Other controls include an automated system which responds automatically to daylight, known as daylight harvesting, which helps to save energy. Automating lighting controls can also be programmed to turn on as part of an intruder alert, or a security warning system.
Natural Lighting Systems
Natural home automation lighting systems involve the use of window shades, draperies, and other systems which respond to natural light. Bulbs which turn off at daylight are one example of this system in operation, and other advances such as the use of radio frequency technology have allowed the user to have complete control from a central panel. Using this on combination with keypads means that the curtains can be drawn at the press of a button, or blinds pulled down once the sensors are triggered by direct sunlight.
All of these devices use up more energy than performing these tasks by hand. You can pull the curtains yourself, but it may be convenient for people who are disabled, or who have problems turning switches on and off. Light control panels are also appealing to men, with their appearance of gadgets, and the look of technology. Families may also appreciate the use of a control switch such as a dimmer or a timed switch, which means that the house can be lit when children are returning from school, and the room can be dimmed at night when the family are watching television.
