Login Error
Close
Home Automation: Troubleshooting X10 Problems
by DoItYourself Staff
Home automation X10 problems can be resolved with basic troubleshooting. Home automation allows you to control devices in your home such as remotes or timers. Automation is a good way to provide security, convenience and also save money on energy bills. Here are some of the common problems with an X10 automation system along with some possible solutions.
User Error
Check that the code for the unit and the house are set correctly.  Be sure that there is power to the module that the outlet for wall switches is working properly. In the case of a dimmer switch verify that other electronics are not being switched.
Faulty Equipment
If the module seems to be faulty you can test it by taking a different module and using the same codes. If the test module works then it may be that the first module is faulty.
Weak Signal
Most houses were wired before home automation was even a choice. The signal from the system gets weaker the further it travels. If you are using several modules you may need a phase coupler. Another reason for a weak signal is signal absorption. Some electronics may be absorbing the signal. You can add a noise filter to resolve the issue.
Powerline Noise
Too much powerline noise will cause the modules not to be able to hear the signals. The source of this powerline noise can be from electronics, appliances or even fluorescent lights. A noise filter can solve the problem if you can identify the source.
Phase Distortion
If the sender of the X10 signal is on a different circuit than the receiver then the signal must go all the way to the breaker box and then to the other circuit to get to the receiver. Two phase wiring is common for home wiring. In the case of 2 phase wiring the signal goes along the circuit from the send to the breaker box, and out to the street transformer, back to the breaker box and then to the receiver. Because of this long distance most of the signal strength can be lost by the time it reaches the receiver. Putting sender and receiver on the same phase may solve the problem. Another option is to install a passive phase coupler so the signal goes from directly from one phase to the other.
Slow Response Times
When using a computerized controller you may notice a delay in the command being executed. You can lessen the delay by using slower device dim rates. Another way to solve the problem if you have an advanced module is to utilize the group control. This allows you to send one single signal that will adjust several modules.
If these troubleshooting measures do not solve the problem with your system then consult you manual or contract the installer or the manufacturer who may be able to offer more assistance. Once you have resolved the problems you will be able to enjoy the convenience of having your appliances, lights and electronics obey your every command.
 forum activity
