Home Decor Bathroom Do's and Don'ts
It is vital to keep some important home décor bathroom rules in mind when you are either building a new bathroom or renovating your existing bathroom. This can be a gigantic task if you are doing it for the first time. The main purpose behind bathroom décor is to enhance its aesthetic value and to redefine the ergonomics and visual style of the place.
Bathrooms have now metamorphosed into more than just the basic facility. There are numerous visual styles, designs and accessories that make your bathroom an essential part of your home. Since bathroom décor is not a small job, there are some important points that need to be kept in mind when taking up this task. These practical points will help you achieve what you really want to do.
Bathroom "Do's"
- Get the right look by going to bathroom showrooms as well as scanning the Internet. You need to be aware of what you want before you start up.
- Get a good plumber, electrician and specialist who will be able to do a good job. These professionals will help you develop a proper plan to make your bathroom look its best.
- Mix up metals. Try not to settle for the same old materials, like stainless steel or porcelain. Try experimenting with new fixtures; choose platinum, copper, nickel or chrome. These will make your bathroom look unique.
- Make sure your choose the best quality items to suit your budget. These will last longer and will not cause any issues in the future since they would most likely be used for an extensive number of years.
- Add aromatherapy candles and salts to give a relaxed aroma to your bathroom. You could also use scented soaps. Be sure that the different aromas you use blend in well and don’t clash with each other.
- Use shower or tub curtains that blend in with the rest of the décor. For example, if the theme of your bathroom is pink, a green shower curtain will look ghastly.
Bathroom "Don'ts"
- Don’t cut corners. Ensure that you get the right advice and implement these ideas completely. Cutting corners will cost you a lot more at a later date.
- Don’t install things yourself if you haven’t done it before. Important installations are best done by the professionals. This will ensure that you do not suffer later on, you will save valuable time and money and will prevent unnecessary headaches.
- Don’t buy the first thing you see. Shop around so that you will not regret your choice later. The last thing you would want is a bathroom that you feel vexed to step into.
- Don’t hire an inexperienced individual to handle the complicated aspects of bathroom work. Get a professional as they will be able to get the job done right the first time.
- Don’t over-decorate. This is a common area in which many people mess up. Some like to have many different things in their bathrooms but the end result is anything but aesthetically pleasing.
