Login Error
Close
Home Electrical Safety Inspection Checklist
by DoItYourself Staff
Regular electrical safety inspection in your home can, to a great extent, help ward off disaster. Every home and office has several electrical safety hazards that must be kept under check. Some of the following points cover the important aspects of an electrical safety inspection in your home.
Are Electric Sockets a Safe Distance away from Sources of Water?
The biggest occurrences of electric shocks and fires occur in the kitchen and bathroom, because these areas tend to be moist. Avoid using space heaters in the bathroom and never use electric appliances close to accumulated water or on wet ground. In the kitchen, ensure that all wires and cords are adequately protected from oil, moisture and heat.
Do All Electric Appliances Function Properly?
An appliance that causes mild electric shocks or overheats must be immediately repaired or replaced. Also make sure that you operate appliances properly.
Is There Sufficient Clearance around Electric Appliances?
All electric appliances must have enough clearance on all sides so that they do not overheat. Ensure that children stay away from electric appliances.
Are Wires and Cords Properly Insulated and in Good Condition?
Torn or frayed electric wires and cords represent an electric hazard. Regularly inspect all electric cords and ensure that the insulation is intact. If not, have them replaced immediately.
Are All Electric Cords away from Foot Traffic?
Electric cords must always be placed away from the high traffic areas in your home, otherwise they may cause people to trip and fall. Additionally, the wires may get damaged and cause an electric shock. Also, avoid placing rugs or furniture over electric cords, because they remain hidden from view and can get damaged faster.
Are Outdoor, Bathroom and Kitchen Sockets GFCI Protected?
All electric outlets in the kitchen, bathroom and outdoors must be GFCI (Ground Fault Circuit Interrupter) protected. These are the areas that are most prone to electric accidents and a GFCI protector stops the current before it becomes dangerous.
Are Unused Electric Appliances Unplugged?
Small electric appliances that are not in use must be unplugged, especially if the children have access to them or if they are close to water.
Are All Electric Appliances Tested for Safety?
Only buy electric appliances that have a seal of safety from a reputed testing laboratory. These appliances are extensively tested for safety issues and are safer in your home.
Are Unused Sockets Covered by Safety Covers?
Unused electric sockets must be covered by plastic pads that make them inaccessible to young children. Poking or touching wall sockets with objects can lead to serious electric shocks.
Are All Sockets Cool when Touched?
Hot or discolored sockets are a sign of impending trouble. Another warning sign is a burning smell emanating from an appliance or socket. Contact an electrician immediately for either problem.
Are Extension Cords Used?
Avoid using extension cords permanently. These devices are only meant for use in short term situations. Also ensure that the cords are in good condition and the extension cords and circuits are not overloaded.
Are Lamps Kept a Safe Distance away from Combustibles?
Lamps emit a lot of heat and must be kept a safe distance away from anything that can ignite. If a lamp topples over, it can overheat and start a fire.
 forum activity
