cancel
Find Qualified
Local Contractors
Select Service:
Enter Zip:
community forums
Email Page   Print Page
Home Energy Audits – part 2
comments
  • Currently3.08/5 Stars
  • 1
  • 2
  • 3
  • 4
  • 5
out of 312 votes
By Guy Cozzi
2) Insulation: Heat loss through the ceiling and walls in your home could be very large if the insulation levels are less than the recommended minimum. You should check to see if the level of the attic and wall insulation of your home is at least at the minimum recommended amount. When your house was built, the insulation recommended at that time was installed. Given today’s energy prices, and that future prices probably will be higher, the level might be inadequate, especially if you have an older home. In 1997, the U.S. Department of Energy updated its recommended insulation R-Values.
If the attic hatch is located above a conditioned space, check to see if it is at least as heavily insulated as the attic, is weather-stripped, and closes tightly. In the attic, determine whether openings for items such as pipes, ductwork, and chimneys are sealed. Any gaps should be sealed with an expanding foam caulk or some other permanent sealant. If you have recessed light fixtures, determine if they are IC rated fixtures. It is strongly recommended that only air tight-IC rated fixtures be used. Other types allow large amounts of your heating dollar to escape into the attic. If you do not wish to purchase new IC rated fixtures, be certain to allow a three-inch space around any recessed lights. This will prevent the recessed light from overheating.
While you are inspecting the attic, check to see if there is a vapor barrier (retarder) under the attic insulation. The vapor barrier might be tar paper, kraft paper attached to fiberglass batts, or a plastic sheet. If there does not appear to be a vapor barrier, you might consider painting the interior ceilings with vapor barrier paint. This reduces the amount of water vapor that can pass through the ceiling. Large amounts of moisture can reduce the effectiveness of insulation and promote structural damage. Make sure that the attic vents are not blocked by insulation. You also should seal any electrical boxes in the ceiling with flexible caulk (from the living room side or attic side) and cover the entire attic floor with at least the recommended amount of insulation.
Checking a wall’s insulation level is more difficult. Select an exterior wall and turn off the circuit breaker or unscrew the fuse for any outlets in the wall. Be sure to test the outlets to make certain that they are not "hot." Check it with a lamp or portable radio. Remove the cover plate from one of the outlets and gently probe into the wall with a thin, long stick or screwdriver. If you encounter a slight resistance, you have some insulation there. You could also make a small hole in a closet, behind a couch, or in some other unobtrusive place to see what, if anything, the wall cavity is filled with. Ideally, the wall cavity should be totally filled with some form of insulation material. Unfortunately, this method cannot tell you if the entire wall is insulated, or if the insulation has settled. Only thermographic inspections (discussed below) can do that.
If your basement is unheated, determine whether there is insulation under the living area flooring. In most areas of the country, R-25 is the recommended minimum level of insulation. The insulation at the top of the foundation wall and first floor perimeter should have an R-Value of 19 or greater. If the basement is heated, the foundation walls should be insulated to at least R-19. Your water heater, hot water pipes, and furnace ducts should all be insulated.
3) Heating/Cooling Equipment: Inspect heating and cooling equipment annually, or as recommended by the manufacturer. If you have a forced air furnace, check your filters and replace them as needed. Generally they should be changed about once every month or two, especially during periods of high usage. Have a professional check and clean your equipment once a year. If the unit is more than 15 years old, you should consider replacing it with one of the newer, energy efficient units. This would go far to reduce your energy consumption, especially if the existing equipment is in poor condition. Check your ductwork for dirt streaks, especially near seams. These indicate air leaks, and they should be sealed with a duct mastic. Insulate any ducts or pipes that travel through unheated spaces. An insulation R-Value of 6 is the recommended minimum.
4) Lighting: Energy for lighting accounts for about 10% of your electric bill. Examine the wattage size of the light bulbs in your house. You may have 100 watt (or larger) bulbs where 60 or 75 watts would do. You should also consider compact fluorescent lamps for areas where lights are on for hours at a time. Your electric utility may offer rebates or other incentives for purchasing energy efficient lamps.
Continue here
© 2007 Guy Cozzi. Get more advice on energy efficient house repairs, real estate investing, house inspectors, and home appraisers at Nemmar Real Estate Energy Efficiency Repairs.
member comments
or Register to leave a comment
articles we like
Growing Bonsai Outdoors
This article provides information about training, pruning and watering bonsai trees, and also discusses whether... read more
Manufactured Homes Stir Up Indoor Air Quality Concerns
Paul Bianchina responds to questions that have arisen in recent years concerning indoor air quality... read more
How to Find the Cheapest Airfares
How to Find the Cheapest AirfaresEver wonder what the guy sitting next to you paid for his airline tickets? Chances... read more
sponsored articles of the day
diy centers
