Login Error
Close
Home Office Soundproofing: How to Keep Your Home Office Quiet
by DoItYourself Staff
Home office soundproofing is a great way of improving your working atmosphere and increasing your overall efficiency. Sometimes, external sounds such as the drone of machines or the voices of loud neighbors can be quite distracting. By understanding the basics of sound and how to block it, you can easily soundproof your home office. You can achieve basic soundproofing with cheap materials. You also have the option of spending some money and getting professional help with office soundproofing.
Soundproofing during Planning and Construction
If you are in the process of building your home, there are several things you can do to implement effective soundproofing. First, plan your home office in such a way that it is located in the quietest location of the house. This is probably the cheapest method of soundproofing. You can also consult the contractor and arrange to have the home office built with soundproof materials. A double-walled structure is excellent for containing and blocking noise. Also, a dropped ceiling can deter noise. Consider all these options and choose one that suits your need and budget.
Weather Stripping
Noise travels through thin materials and gaps in construction. You can block out much of the noise from your home office by ensuring that the space is as insulated as possible. Look for all the small openings and crevices in the room. You will usually find these near the doors, windows and electric outlets. Add weather stripping along the window edges. In addition to blocking noise, weather stripping will help you reduce your energy bills. Also do the same for the space underneath doors. The weather stripping will not inhibit opening and closing of the doors, but it will prevent air and noise from traveling indoors when the door is closed.
Caulking and Other Office Soundproofing Measures
On the walls and floors, you may find some cracks and openings as well. You will have to fill these up with caulking, Spackle or wood filler. You can also install storm windows in your office room. In addition to weather protection, they will act as noise inhibitors. Thick rugs on the floor also absorb a great deal of noise. Thick drapes are another option. For the spaces around electric outlets, you can purchase foam covers that you fit underneath the outlet plate.
Additional Layers
Fibrous and porous materials work well for home office soundproofing. They absorb sound waves instead of allowing sound to travel through. As a result, by adding a porous element to the walls and floors, you can greatly reduce noise. One of the options is to add a concrete block in front of the walls. However, this option may not always be suitable for every budget. Another option is acoustical foam, which is a product you can install over the walls. If you are not concerned about appearance, you can hook up some thick rugs or foam cartons on the wall as well.
 forum activity
