Login Error
Close
Home Remedy for Clogged Sink Drain Problems
by DoItYourself Staff
what you'll need
  • Plunger
  • Baking soda
  • Plain white vinegar or cider vinegar
  • Salt
  • Boiling water
One of the common nuisances in everyday life is to discover that something at home is not functioning right, and a clogged sink drain is by far the most frequently recurring problem. It may not be a huge issue, and with some useful home remedies you can solve it in no time. Here are a few simple steps to help you unclog a sink drain using items around the house.
Step 1: Use a Plunger
First, fill the sink basin with water. Block any alternative outlets, such as the sink overflow, and then start to push the plunger with several strong strokes. If the blockage is not too problematic the plunger should solve the blockage by bringing up any debris and waste fragments.
Step 2: Pour Boiling Water
Boiling water is the simplest and cheapest method. If the blockage is not substantial it might be enough to solve the problem. Simply boil water in the kettle and pour it down the drain.
Step 3: Try Using Baking Soda
If the drain still remains blocked try to pour half a cup of baking soda down the drain. Afterwards, pour about three cups of boiling water. The baking soda and the hot water cause a reaction that may dissolve and move through the clog.
Step 4: Try Using Salt
Salt is often used with cleaning products, as it is believed to elevate the cleaning effect. Adding salt to the baking soda and hot water concoction may help to achieve the desired effect. First, pour half a cup of salt followed by half a cup of baking soda. Finally, add in a cup of boiling water and ideally leave overnight to give it time to dissolve the clog.
Step 5: Use Vinegar
If the previous method does not fix the problem and you think that the sink might be blocked due to grease, try to use vinegar with baking soda. First pour half a cup of baking soda down the drain. Immediately after that, pour down half a cup of vinegar. Ideally, use plain white vinegar or cider vinegar. Afterwards, cover the drain for a few hours to let the two chemicals react together, and later flush down with boiling water.
If nothing above manages to resolve the clogged sink drain, you may need to resort to technical advice. However, it is usually more a matter of common blockages caused by residuals that we carelessly dump in the sink.
 forum activity
