Login Error
Close
Home Remodel Tax Deductions
by DoItYourself Staff
As spring approaches, the words "home remodel" sticks in every homeowners' minds as they start to consider home improvement projects to start. But before hiring a contractor or starting out with hammer and nails, you should check whether your home remodeling may be eligible for home improvement tax deductions. By taking a loan to cover much needed home remodeling, you may be able to reduce your taxes through tax deductions. Not all types of home remodeling are eligible for tax credit or tax deduction. But there are certain cases of home remodeling in which you can decrease your taxes not only for the calendar year, but for the years to come.
Repair vs. Remodeling
A homeowner should know the difference between home remodeling and home repairs. Put simply, home repairs fix a problem. For example, fixing a leak, repairing a hole in the roof or repainting a room come under the category of repairs. But remodeling consists of: adding a couple of rooms, installing a swimming pool, building a garage or remodeling the kitchen. These improvements add to the living amenity of the homeowners. The value of the home also increases due to remodeling.
Medically Necessary Remodeling
There are certain strict guidelines provided by the Internal Revenue Service that needs to be followed by every homeowner seeking tax deductions. It is recommended that before starting a home remodeling work or hiring a contractor, the homeowner should consult the local IRS office or a tax consultant. There can be any of several different categories in which your home remodel tax deductions may fall. Home remodeling is also considered for tax deductions when one needs to remodel the house for a medical condition that requires providing disabled access to home.
Repairs as Remodeling
You may be able to include repair as an improvement or remodeling in case if you are planning a remodel in that area of the house which needs to be repaired too. According to the Tax Act, if a repair is needed in the remodeling area then this repair can be added on as a part of your remodeling project. For example, if you are thinking of remodeling your kitchen then you can also take care of the pipes that are leaking and you can also claim the entire project as a deduction.
Remodeling for Tax Credits
A significant amount of savings can also be provided by tax credits. There are many types of home improvements for which tax credits are available. For example, you may qualify for tax credits if you are planning to add energy efficient windows, installing insulation, solar water heating and some other type of highly efficient equipment for heating and cooling.
Homeowners can assist themselves by reading various publications from IRS on home remolding tax deductions. A great amount of information can be found by calling the IRS branch office or visiting their website.
 forum activity
