Home remodeling loans are available to those planning major projects outside of a normal budget. A loan can be beneficial cushion so long as it has an interest rate that suits your needs and abilities.
Factors Which Effect Home Remodeling Loan Interest Rates
- Credit score
- Income
- Debt ratio
- The value of your home
- Necessity and estimated cost of your remodeling job
Getting a Lower Interest Rate
Most of the factors that affect a loan interest rate can either not be changed or would take a long time to change. The factor over which you have the most control is the plan for your remodeling job. Keep these tips in mind when applying for a loan:
- Remember: when you take out a home remodeling loan, you use your home as collateral.
- Explain to the lender what you will be doing to your home and why.
- Reduce risk to the lender by planning changes that will actually increase the value of your home.
- Use a contractor. The lender will feel more comfortable knowing that the remodeling job will be done correctly.
Questions of a Do It Yourself nature should be submitted to our
