Login Error
Close
Home Security Camera Software Instructions
by DoItYourself Staff
Using home security camera software provides enhanced security while limiting your costs on videotapes and other storage mediums. This software records directly to your computer's hard drive, making review and removal quick and simple.
Picking Out the Right Home Security Camera Software
Many home security companies offer software specifically designed for their cameras. There are also a number of aftermarket software applications that are compatible with a large number of different cameras. When picking out home security camera software, research to find one that will meet and exceed your specific needs.
Positioning Your Security Cameras For Effective Use
When positioning your cameras, make sure that they will effectively capture the face of anyone who may be entering your home. For most locations, your goal should be to put the camera far enough back that it will be able to capture the face despite the fact that it is fairly high up. The most difficult position is the front door where it is often impossible to position the camera far enough away. For the front door, a door camera is often the best option.
Using Home Security Camera Software Effectively
Each software title designed to operate with home security cameras has its own feature sets. Read the supplied manual to gain familiarity with the product and its possibilities.
Most software titles include standard or common features, such as motion-detected recording. This feature will allow you to save valuable hard drive space by recording only when motion is detected. Using home security camera software, you can view your different cameras at any point directly from your computer.
When using the recording feature of your software, it is recommended that you have it capture images in incremental time values, like 10 to 20 seconds is a good time range. This helps to limit the amount of hard drive space required to store the video.
 forum activity
