Login Error
Close
Home Security for Bedroom Windows
by DoItYourself Staff
There are many aspects to consider when planning your home security. What kind of security alarms are available to purchase? Do you need a monitoring system or do you feel secure enough with loud sirens or flashing lights? Windows are oft-neglected access points to your home. Be sure to install security measures on your windows to ensure that your family and possessions remain safe.
The Types of Alarms Available
Home security is a billion dollar a year industry with dozens full-service home monitoring system providers. Luckily, there are not as many systems designed to protect windows, which can help narrow your options. Let the size and structure of your house determine which types of security decices you use.
  • Magnetic alarm
  • Motion detector with light
  • Lock mechanism
  • Grate
  • Panes
Magnetic Alarm
This is the most common and least expensive type of alarm. It is comprised of two plastic things with screw holes. You mount one to the window frame and the other to the window, directly across from each other. If the window is opened, the magnet breaks and an alarm sounds, startling a burglar.
Motion Detector With Light
A motion detector is placed outside the window and attached to a light and/or an alarm. Once the detector locates movement outside, an alarm will sound and the spotlight will come on it illuminate a trespasser. These systems can be adjusted to respond only to movement from beings that are a certain size or weight, so as to ignore birds, squirrels and even outdoor pets.
Lock Mechanism
Ensure that you have locks on every window in your home—even on upper floors. The best window locks are made from steel and are attached to the frame, not just the window. You can also find locks that can be placed at the top of the window frame which makes them more difficult to reach without a ladder.
Grate
This security option is not all that appealing, but it certainly works. Install a metal grate or bars over the window and mount directly to the outside wall of the home. This is especially effective on ground-level windows.
Panes
Panes of glass are very fragile, but Plexiglas is strong. Try this cost-effective alternative as it can also help your home heating and cooling. Also consider using thicker glass or double paned windows.
 forum activity
