Login Error
Close
Home Studio Design: 8 Easy Ways to Make Your Home Studio Acoustically Balanced
by DoItYourself Staff
There are a number of ways to incorporate an efficient home studio design in your basement or any other spare room. A home studio is the place where you create your recordings, so it is in your best interests to set it up as perfectly as possible before you begin any work. In addition to bringing out the best sound results, an acoustically balanced home studio will also help keep sound indoors so you do not disturb your neighbors. There are several easy ways to make your home studio acoustically balanced.
1. Identify the Potential Problems
For best results, you must have high quality equipment such as the microphone, mixer, speakers, etc. But the room in which you record is just as important. In a normal room sound waves will bounce off surfaces and create many interfering noises. Also, there are bound to be many small gaps and crevices that will let in sound waves and also transfer them outdoors. The net result will be a lot of interference in the final result. Look around and find all the minute openings in your home studio. Also include the gaps around electric outlets and fixtures. Other problem areas include the space around windows and doors.
2. Seal All the Openings
The first step to achieving acoustical balance is to cover all the openings you find. Use caulk, weather stripping and joint compound to seal all the holes, crevices and gaps around windows and doors. You can also get professional advice on proper insulation.
3. Use Padding
Acoustical foam is a product that is commonly used to absorb sound waves. You can have it installed on the floor and walls as well. It is an easy, economical way of improving the acoustical balance of your home studio.
4. Add a Dropped Ceiling
A dropped ceiling is a great way of muffling noise. This is because there are two layers that make up the structure. Most sound waves that infiltrate are trapped in the void between and do not pass through to the room.
5. Install Double Walls
This is a costlier option that requires professional assistance. Double walls work the same way as dropped ceilings and muffle sound. Professional studios use thick, soundproof glass and specially constructed doors that block most of the noise. You can also get professional advice on how to improve your windows and doors in the home studio.
6. Use Thick Carpets
Sound travels easily on bare floors, which is why we are all familiar with creaking sounds on hardwood floors. Even on bare concrete floors, sound has a way of traveling through. Thick carpets and rugs do a great job of muffling unwanted noise.
7. Ensure Proper Placement of Appliances
Place the microphone in a location where it will catch all the required sound and none of the unwanted squeaks or movements. Make sure there is no interference from nearby equipment. Turn off all unwanted appliances during recording.
8. Buy Acoustical Treatment Sets
There are several companies that offer acoustical treatments packages, which help diffuse, trap and muffle sounds. You can buy a package that is most suited for your home studio setting.
 forum activity
