Login Error
Close
Home Vinyl Siding Colors and Options
by DoItYourself Staff
Once you have chosen home vinyl siding as your material to finish your home, there are few decisions left to make about your siding. But the work is not done because vinyl siding comes in a wide variety of styles and colors. All of the sidings offer different appearances and functional advantages. If you are in the process of making the decision about which type of siding to buy, you should carefully consider all of your options before making your final purchase. What follows should help you understand the differences between the multitude of types and colors of siding, making your final choice much easier to make.
Board and Batten
Board and batten type vinyl siding is designed to emulate the look of traditional wood siding of the board and batten type. In wooden board and batten siding, outer boards are alternated with inner battens for a strong and aesthetically pleasing structure. This particular type of vinyl siding makes your home look simple and traditional, while gaining the increased lifespan and decreased maintenance that comes with vinyl siding when compared to wood. Board and batten vinyl siding is a great choice for anyone who is having trouble choosing between wood and vinyl siding, or anyone who is still tempted by the appearance of wood siding.
Dutch Lap
Dutch lap style vinyl siding is another kind of vinyl siding that emulates the appearance of traditional wood siding. However, dutch lap style vinyl siding has quite a different appearance than board and batten siding. Dutch lap siding involves individual pieces of siding overlapping each other at an angle, as opposed to the alternating flat boards of board and batten style siding. As a result, you should carefully consider which appearance you prefer if you want to emulate the look of wooden siding with vinyl.
Seamless
Seamless vinyl siding is designed to avoid the visible seams present with shorter types of siding. While in reality seamless siding merely comes in longer pieces than traditional siding, in practice this results in a lack of seams in all but the most unreasonably long walls. Seamless siding is an attractive and functional type of siding that can be used in many ways to increase the aesthetic value of your home's exterior.
Liquid
Liquid vinyl siding is quite different that the other different types of vinyl siding. Instead of coming in pieces and being installed the way traditional siding is, liquid vinyl siding is a liquid that can be applied like paint. While this may not seem very impressive, consider the following. Liquid vinyl siding can last for decades, resist all kinds of moisture, heat, cold, and decay based damage. While moderating the temperature of the inside of your home. Liquid vinyl siding can serve all of the purposes of traditional siding, all while being simple to install and environmentally friendly.
Colors
Vinyl siding comes in a wide variety of colors. However, vinyl siding generally only comes in light colors because dark colors absorb more heat. Absorbing enough heat can damage vinyl siding, so to prevent this from happening vinyl siding comes in light colors.
 forum activity
