Hot Topics: Deck Nail Removal Hot Topics: Deck Nail Removal
Here at DoItYourself.com we enjoy providing a place where home improvement novices and experts can come together to share ideas and advice. Inside our Forums, users can browse threads to see what exchanges are taking place on a topic of interest or start their own dialogue by posting something for the community to take part in. With over 250,000 members and counting, this resource is quite active so each week we highlight one of the conversations that may just help you with that next DIY project.
Original Post: Having problems removing nails from my deck.
kathyc43 Member
When we remove the decking boards, the nails don't come out with the boards. Can I just bend them over the side with a hammer instead of removing each one?
Highlights from the Thread
Pilot Dane Group Moderator
That depends on what you want to do. If you are dismantling the deck then there is no need to remove them. If you are going to install new deck boards I would pull the nails so your new boards can rest flat on the joists. Even hammering nails over some bit of them usually ends up sticking above the wood.
kathyc43 Member
There are several rows of deck boards, each replaced at different times for some reason. This row was in poor condition so we are replacing it. My friend is taking up the old boards, which crumble as they are pried up, leaving the nails behind. I try to remove them but they are very difficult to remove.
stickshift Group Moderator
They will need to be removed. What tool are you using to do this?
kathyc43 Member
I am using a claw hammer to remove the nails.
aka pedro Member
Claws on a hammer are there for convenience, and are not necessarily the best choice when pulling nails is the primary task. Stop by your local hardware or big box and ask them to point you toward flat bars. They have a long and a short leg, each with a slot to pull nails. Once you have that in hand, you may find that a short piece of the scrap wood makes a good fulcrum to place under the bar and increase your leverage.
Read more at: //www.doityourself.com/forum/decks-patios-porches-walkways-driveways-stairs-steps-docks/551968-too-hard-remove-nails-deck.html
